I have parralleled two Aleph 3 channels in order to drive a low impendance load of two scan speak 7 inch woofers. (this is a bi-amped system)
One aleph channel powering that load sounded pretty good...I think that the two parralleled channels sound better...or is this my imagination?
If they are perfectly matched, generally yes.
The problems arise from the channels not being identical,
as they then will argue with each other. The lower the
output impedance, and the more feedback, the worse it
gets. Alephs are pretty laid back with regards to these
parameters, and so they get along pretty well.
For amps with lots of feedback and/or high damping factors,
it helps a lot to (a) match the gain carefully and (b) adjust
the DC offset to match.
After that, it often is helpful to place some resistance in
series with each amp's output, say a fraction of an ohm,
which limits the amount of current which will flow from one
amp to another.
So why do this? Because the distortion of most amps is
highly dependent on current, reducing the output current
requirements of each amp will drop the distortion fairly
dramatically. This is also a reasonable way to tackle very
low impedance loads.
Zens and Alephs seem to love being paralleled; just connect
the inputs and outputs together.
amp to another.
Nelson:
In audionut's scenario he could just as well drive each of the woofers separately using one channel of the Aleph for each. Yet it's in his mind to parallel both amps and woofers. Based only on the information you provided, there is no difference . . . or is there?
audionut said:I've got long wire runs to the speakers...so I use one pair of heavy guage wire...
A separate long cable for each parallel amplifier might fill the
bill.
"In audionut's scenario he could just as well drive each of the woofers separately using one channel of the Aleph for each. Yet it's in his mind to parallel both amps and woofers. Based only on the information you provided, there is no difference . . . or is there?"
Not much, except of course, that issues about amplifiers
arguing go away.
- Parralleled Alephs
