Got a Park Amp that's the speaker is fine and not blowing fuses but gets no volume....just a soft buzz/ fuzz guitar tone. Any ideas what to check anyone?
Check DC voltages first.
Then click/touch the middle point of the volume with ascrewdriver(vol not set to minimum). If it gives a loud buzz/pop, the power amp works ok.
Gajanan Phadte
Gajanan Phadte
Connect Black probe of DMM to the ground(Chasis or Barrel of RCA phono) and connect Red to wherever you want to measure. Be very careful so that the probe does not short two connections/tracks.
Warning: Mains connections will be accesible and is lethal.
Gajanan Phadte
Gajanan Phadte
