Parasound HCA-800II and C/PT-600
Hello, I haven't posted here much but I have browsed the forums in the past. Now I am getting desperate....
I have a Parasound HCA-800II which I have recapped using Nichicon FG and KZ (Muse) in the audio path. About 1/3 of the electrolytics had drifted out of spec. The difference in SQ is stunning. This is a great little amp driving my 4 ohm Polk LSi-15's.
I also have a Parasound C/PT-600 preamp/tuner which I also recapped but only the audio section with nice improvement in SQ. I did not touch the tuner as I don't have a service manual to do the alignment. However, the tuner section is now going flaky. I contacted Parasound but they don't have any info on this unit anymore. Apparently it shares the same tuner section as the C/PT1000R preamp/tuner and the R/HD-600 receiver. Unfortunately, I can't find anything on these either.
I may have to punt work over the tuner and figure out the alignment later. At this point, there is not much to loose.
Anyone have a service manual for the C/PT-600, C/PT-1000R or the R/HD-600? Can anyone help?
Stan
