Does anybody know anything about this adaptor or how 1 could aquire. There seems to be no info anywhere and Parasound hasn't had this part for like 4yrs.😕
Some info from the manual:
An optional Advanced Digital Adapter Module (ADAM) is available from your Parasound dealer. The
ADAM features the AT&T glass fiber ST module and the AES/EBU standard using a 3 pin XLR connector.
Either of these will provide superior sound if your D-A converter is equipped to accept them.
The advantage of the AT&T glass fiber optic connection is that it electrically isolates your player from
the rest of the system, with a potential for a lower noise floor. The AES/EBU output offers a balanced
output with a separate ground. It is very easy to install the ADAM yourself. Insure that the C/DP-1000
is unplugged before attempting to install the ADAM. Remove the two screws at either side of the cover
plate near the left side of the rear panel on your C/DP-1000.
