I wanted to know if anyone here has used iraudamp7d in parallel mode. If yes then what were the results and if no then is it possible to use it in parallel mode?
I intent to used both the channels in parallel so i can drive 2ohms load.
So i need a little advice on this regard
I would recommend bridging the outputs rather that using parallel mode.
I did a similar design for myself and I used bridging mode and it works great.
Thanks for your feedback but i want to use it in 2ohms load. Did u ever try to use it in parallel mode?
If you bridge it, DO NOT use a 2R load. You will have toast if you do!
Bridging will double the resistance. I am aware of that. But my question is specifically regarding paralleling it. So can u tell me is it possible with this amp?
