Thinking of using ecc99, parallel triodes, to drive 2A3 or 45.
Saw from previous posts about pros of parallel.
No change in gain (Of course loudness is not an issue in my case)
GM=2x
Internal resistance/2.
Any weak points to consider in this approach?
GM=2x
Hi there, some people say it doesn't sound as good as a single triode half. I reckon it depends on the application, e.g. the lower driving impedance may do better job of driving the grid.
My suggestion it to try it both ways and decide for yourself.
Pete
Pete
Depends on triode matching inside the bottle - not overly problematic for completely separate triodes, since you can still use separate cathode resistors and bypass. With common cathode double triodes, you get a new triode which may be significantly off from Gm*2, Rp/2... but that does not mean it will sound worse. Just think of it as a different triode and optimize for that.
