Hi! I have come across with this topology for power supply filtering in a Class D design. It seems like a good idea.
http://www.lcaudio.com/index.php?page=45
I wonder if anyone tried this on tube amp and use this topology instead of the traditional CLC filter?
What is good about it? a resistance that low doesn't do much for filtering.
I think you will find that a CLC supply is superiour to any CRC supply as a choke acts as a high impedance for AC but very low for DC which give a much more efficient filtering.
Regards Hans
I'll agree with Hans,
The supply in the link would need to have it's values adjusted a lot. It's still not a good idea. C-L-C supplies are best used when there is a minimum load current over the critaical value for the inductors, or the ripple voltage goes up and the filtering action of the choke is lost.
An electronic regulator before the voltage amp section would enhance the performance of an amplifier.
-Chris
-Chris
ackcheng said:Hi! I have come across with this topology for power supply filtering in a Class D design. It seems like a good idea.
It is a good idea for a solid state amp. The big difference is that this is a low voltage, high current PS. VT's are high voltage, low current devices, and so, you'd be better off with the usual CLC filter. The "LC" + load resistance part of the CLC forms a second order LPF that gives -12db/octave of roll off. The RC filter is a first order LPF with just -6.0db/octave of roll off. That's twice the ripple attenuation with the LC design.
This just won't translate to the high voltage, low current situation. Best keep it for your mega-power SS designs.
