This may be a bad idea... but has anyone tried paralelling bridge rectifiers?
Not necessarily for more current but for reducing the impedence and therefore maybe the voltage drop....
My concerns are around RF, current hogging (fix with 0.05 ohm power resistor?) 🙄
Any thoughts from the gurus?
thanks!
thanks!
K-amps said:Not necessarily for more current but for reducing the impedence and therefore maybe the voltage drop....
paralleling rectifiers will NOT reduce their voltage drop (well, it does but just too insignificant as Vf does drop a little with Ic).
balancing the two can be very tricky.
if forward voltage is your goal, try schottky rectifiers. if current is your goal, get a beefier rectifier.
