Parafeeding a push pull
Mumble mumble ... I searched the forums but I didn't find any post on parafed push-pull stage.
Probably I am missing the point but I think that leaving the dc supply out of the tranny can be welcome also in a push-pull. The tubes can be loaded by a (large choke) and capacitor coupled to the OPT.
Any comment or reference to look at? 😕
Gianluca
Well tube balancing is one aspect. I was considering that a parafed PP trans can be winded with smaller gauge wires, as no DC current will flow, giving smaller dimensions.
The real question should be: can this improve the THD and freq/time response as the leakage inductance and stray capacitance can be made smaller? Probably it would be a negligible effect and, that's an adverse effect, you are adding a capacitor in the signal path.
Actually the question came out while considering the possibility of using an old SE trans for a PP stage.
Gianluca
