Are there any Nelson Pass-designed phono preamp schematics floating around? If not, where would you point a guy looking for a simple DIY phono state in keeping with Papa’s general design philosophy?
there is a smd new ones if search here , btw buy direct from Papa...PassDiyAre there any Nelson Pass-designed phono preamp schematics floating around? If not, where would you point a guy looking for a simple DIY phono state in keeping with Papa’s general design philosophy?
In 1977, NP designed the Threshold NS10 preamp. It is a phonostage plus a linestage plus volume control, balance, input switching, and tape loop. The schematics are floating around, google will find them for you. You want the variants that are hand drawn and include the wildly obsolete double-diode part number MSD7000.
The original schematic, or the improved one with updated components value - which one is better ?
Why not build each of the variants and then carefully listen to them? When complete, you will know with great certainty, which one YOU think is better.
After all, it doesn't really matter what somebody else prefers, does it?
- Papa phono pre?
