Pace MBT-100
The fuse is the easy part.
Did you contact the seller to ask if it is lying on their desk?
You may find a fuse cap to fit in the existing holder, but they are not all alike, so open it up and find the brand of holder and its dimensions. if you casn find the same model holder in Mouser or the others, order it and just use the cap.
it is also possible you can find a similar holder that will fit in place of the original, and you can replace th entire holder. believe me I have done it in many amps.
