PA-060 use
Looking for a stereo circuit recommendation where I can use a spare MQ power transformer (pa-060) 720vct/300mA, 55v bias, 2x 6.3v@5A, 5V @4A. Not too bothered about power output but I do have a restriction on chassis size, its ~10x14. Thanks
gtmcgar1,
What is your preamp situation? If you don't have a preamp, consideration should be given to constructing an "integrated" amp.
Your power trafo lends itself to construction of a PP stereoblock. If the idea of an "integrated" amp is appealing, a 12AT7 differential splitter/driver feeding a PP pair of 7591s will reach full power directly driven by a CDP.
Thanks for the replies. I should clarify my post, sorry. The PT is left over from an st70 rebuild, its new so I wanted to put it to use to make another (non st70) amp. I have a stereo chassis available also. With the integrated amp suggestion I'm thinking maybe I should do a preamp linestage or an integrated since I already have a pair of 300b monos. If you have a schematic for the 7591 integrated or any other suggestions for a line stage that will work with this PT please post the schematic. Thanks Gordon
Gordon,
Look here. It's a fairly recent thread that addresses many of your questions.
You don't have to get involved with the fancy O/P "iron" John did. Owning 300B monoblocks implies reasonably efficient speakers. You will do fine either triode or ultralinear wired.
I've given some thought to using your power trafo in a PP 7591 "integrated" stereoblock. You will need 2 chokes, but no additional power trafo is required.
B+ rectification will be done by a pair of 6AU4 damper diodes. A CLC filter will be employed.
The B- supply will be derived from the 5 VAC winding via a voltage multiplier made from "noiseless" Schottky diodes. The O/P of the multiplier will feed a Hammond 154E 20 H./20 mA. choke followed by additional capacitance. Ripple will be nice and low.
Each of the 6.3 VAC windings will energize a 6AU4, a 12AT7, and a pair of 7591s. Please observe that the total draw is well under the max. allowed.
BTW, take some time and read the "El Cheapo" saga. The 12AT7 splitter/driver was 1st worked out there.
