P3A transformer question
I'm planning to build the P3A.
On the construction site: http://www.anidian.com/audio/construct/p3a_1.shtml
there is a little calculator that lets you fill in the power you want and then calculates the transformer.
What is meant by VCT?
My local store sells toroid transformers with a secondary voltage of 2x30 V. I guess that's the rail voltage? so 2x30 = 30-0-30 ?
They also say that this is the voltage under load.
Another question:
Has anyone here build this amp with the MJE2955T/MJE3055T transistors?
with 2*30Vac (or 30-0-30) you can get after rectifier and caps about 2*42Vdc. This mean that RMS power on Z=8E is Prms=ca 30*30/8=112,5W.
Power rating of transformer must be higher then 200-250VA.
2N3055 is old transistor. Try 2sa1302/ 2scxxxx.
VCT is the -0- in your 30-0-30. This represents two transformer windings side by side with the tie in the center. As Moamps implied when you convert this from ac to dc you will gain almost 40%. Multiply the 30 by 1.414 to wind up with around 42 to 45 volts dc. When you put this under the load of a circuit (your amp) it will sag (drop down to a lower value). Perhaps your article gives you an allowable % to factor in for this sag. If it is scaleable (bigger power supply voltage for more power out) then it is no big deal just take what you get close enough to what you want. If not, wait for someone smarter than me (there are plenty), or do a search on power supplies. Good luck😉
Even if you understand the idea of a center tap transformer, it is easy to get confused with the way they are listed in many catalogs. For instance, you can find listings that just say 30V but mean 15-0-15. on the other hand if you take it the other way around, you can easily order a 60V unit (30-0-30) when what you wanted was 15-0-15. The Plitron and AvelLindberg websites are unambiguous but some other sources are a pain.
Built a TIP3055/2955 version to use for some experiments. One was cheap and the other was sitting unsused in a drawer here. Not bad but power is limited. I keep the rails at 30VDC or less. If I was going to use it for listning, I'd use 2sa1943/2sc5200
Ok, thanks, I think I understand it now.
What would be the best choice for the powertransistors?
I can't find the ones that Rod recommends.
Are TIP3055/TIP2955 a good choice? Or is there really a big difference in soundquality between those things?
p3a
The toshiba 2sa1302/2sc3281 are in stock @ digikey, after being out for a while. These are excellent flat-paks and they are way easier than the T03 to locate and use.
for that matter the lower rated toshibas in the digikey lineup, (a 1497 & and its complement, I think) would make great drivers (if a bit of overkill) for this amp.
I would ignore what rod sez about these being counterfiet.
Try www.donberg.ie
DIY_Peter is in the EU. Mailorder from digikey might not be his best choice. I looked at Donberg (no umlauts in theURL). They have these as well as the newer replacement parts 2sa1943/2sc5200. I would think it would be cheaper and faster to use an EU source.
Hi!
Well, I used a 30 - 0 - 30 500 VA toroid from Reichelt in Germany (comparatively cheap, 39 €), and as the power transistors I used MJ15003 / 15004, also ordered bei Reichelt (1.55 € and 1.45 €).
Excellent amplifier, and very powerful!
I would recommend using a heatsink for the bigger driver transistors, as they tend to get very hot with a rail voltage of 42 V...
Bye,
Arndt
Cradle22 said:
Hi!
I've got 2 30-0-30 225VA toroids that I was given for free.
I plan to build a dual mono P3A with them.
Have you used your amp with a 4 Ohm speaker? No problems? Rod says that it can't be done with 42V rails
Hi!
Well, your transformers should be sufficient.
Well, I did not try my P3A into 4 ohms, only the six ohms mentioned, but I would say (and there are other postings which support that) that the amp IS capable (I will get the wrath of R. Elliot down on me for that) of running quite stable into 4 ohms at 42 V rails.
Simply use high quality power devices, with high voltage ratings (like my beloved MJ15003/MJ15004), and heatsink the driver transistors, as well.
And use a slightly overdimensioned heatsink. I use 0.6 °C/W heatsinks for each channel, never runs more than handwarm. The driver transistors will get hot, but with small heatsinks they should be OK.
Don't forget that Rod's motto for this is "Better to be safe than sorry", but since most of us do not intend to use their P3A for PA purposes (playback at highest possible volume levels for quite a long time), there won't be too much strain on the devices. And so far I haven't used the highes volume possible with my amps yet, since my source only delivers about 1.1 V at highest level, and even that is much too loud for my neighbours... 😎 especially with my 15" Zebulon Ultra subwoofer... 😀
Bye,
Arndt
