overclocking SAA7220 ?
Bernhard,
When you used the 33MHz crystal, did you measure the frequency? – I suspect that it is a 3rd overtone type – and in fact oscillates at somewhere near 11.2896 when connected to the 7220 XO circuit. I understand that the SAA7220 gets very hot at the best of times, and I cannot image it operating at 33.8688MHz! – not to mention serial clock speeds between other devices.
I would really not recommence operating the 7220 any faster than its rated Max Clock speed - most seem to have a great problem operating at 11MHz - and are very sensative to operating voltage - I remember once seeing a batch of Marantz CD players (CD65 I believe) that had to modify the VCC rail to allow the SAA7220 to operate...
John
