Hi
just bought a ovation 810. Only came with the power cable. Any idea where i could get the cable for the computer connection?.
thanks
is the connector different from the regular VGA cable?
thanks
if you use ebay
there is a superb guy on ebay who sells these cables from time to time - search under seller name "skywayflies"
My advice
I would suggest firstly that you search the forum....however, for what its worth the guy I just mentioned has also been known to make up power supplies for the Ovations as well. Alternatively:
It looks as though Maplin & RS Components in the UK make a PSU that might be suitable....I'll try and get the link for you...there must be a supplier in the US as well as both of these are American companies.
Also, people on this forum have made their own Ovation PSU's out of recycled AT power supplies. Its not too hard, you just need common sense a little electrical knowledge and a friend who is competent with a soldering iron
I'm sorry... I did a search, but I didn't see anything about Homeade power supplies! I'll look harder, thanks for the info.
