Output stage bias, quasi-complementary
Try 26mV across each emitter resistor, it was good enough for Barney Oliver.
http://hifisonix.com/wordpress/wp-c...oss-Over-Distortion-in-Class-B-Amplifiers.pdf
I will read the whole article and report back. I perused over it quickly and see it's full stuff I need to fill my brain with. Thank you.
I have found with my quasi designs I don't need any bias as there is no crossover distortion even with zero bias.
Before posting I started low at 10mV across the emitter resistors I had big clean sine waves at full power. I wonder if an FFT would tell us more between a cold and hot bias.
The bias servo should generate a voltage across it, which is equal to each base-emitter voltage drop introduced to signal: In a quasi-complementary output the Darlington pair drops approximately 2 x 600 mV and the Szklai pair 1 x 600 mV. That's 3 x 600 mV in total so there should be around 1.8VDC potential difference between bases of the driver transistors. You may use that as a rough guide. Figures are naturally approximations. We are dealing with "diodes" with dynamic impedance, not with steady voltage drop.
Crossover notch should be more apparent at LOW signal levels than at rated output power level, because the notch cuts a proportionally bigger amount of signal that has lower amplitude.
Additionally, since there is global negative feedback involved it will play its part in correcting distortion, including crossover distortion. In open loop mode the crossover notch would probably be more distinct.
Thank you all for helping out. I did input a signal and watched the output at low signal output and at cold bias there was noticeable crossover distortion. It was only noticeable are really cold to no bias conditions, e.g. 10mA and under. I did settle on 30mA and it sounds fantastic.
SWR amps are usually biased with 2 Ohm load. 2VRMS into 2 Ohms @ 1KHz, adjust until the crossover goes away, no more. Use the return jack for your input point, efx control in the full "wet" position. 120mv input and then raise the master until you get 2VRMS output.
Craig
