Hi folks,
I read in some post that DC offset on the output, exceeding 50mV is bad for speakers; ideally should be 0v offset.
It is measured between the -ve and +ve of the speaker posts right?
http://www.diyaudio.com/forums/showthread.php?threadid=20799&perpage=10&pagenumber=1
Tripath's specs for the TA2024 is between 50mV-150mV.
My sonic-T is getting 55mV/116mV on the output. Do we need to tune this down? Didn't feel safe putting my main speakers to it... currently running a pair of old mini-hifi speakers. 😀
Thanks!
Thanks!
poozebear said:Hi folks,
Thanks!
Don't worry bout it pooze, I bet all of us have 100mv on one channel!? I have 40 and 95 at the moment but have had a lot worse!
Some say that it helps the dynamics, some say you should get rid of any DC....the only way to do that is to fit a correction circuit to the input alla the TA2024C spec sheet.
TA2024C
Have a look at Brian's T-amp on the Ref. T-amp thread
