I am working with an Otari MTR-10 tape machine. I noticed that the power supply that is labeled + and - 26 volts both on the schematic and the front panel indicator lamp only puts out + and - 22.5 volts. However, I have checked the circuit, and it seems to be working. It is based on a 15 volt zener diode, and calculating the resistor divider in the circuit suggests that it is designed for 22.5 volts, not 26. Does anyone have experience with this unit (either MTR-10 or MTR-12) who can confirm what voltage should be there? Thanks.
I have an mtr-12 and manual.
It does show 26v.
What voltage do you measure coming off of the power transformer?
And what voltage is your line source input voltage as there are three taps for 100v,107v and 117v.
Is it possible that that the wrong tap is selected?
You should have 21 vac feeding each half of the regulator circuit.
acording to the manual.
The 26v power supply feeds a bunch of 78xx type regulators and the voltage drop could be due to a large current draw and is probably no cause for alarm.
What happens to the voltage when the power supply is seperated from the circuits it is feeding(if they can be seperated)?
I will pull my machine (mtr-12) out and verify these voltages for you.
The difference (ratio) of 26v/22.5v is 1.15 which is why I question the input taps.
what is your line voltage?
It does show 26v.
Thanks for your help, geraldfryjr. My voltage selector plug seems to be set for 118 volts, and I probably have 120 volts coming in. The transformer taps for this circuit are labeled 21 volts, and I have about 24 volts AC on both sides. After the rectifier and main capacitors, I have + and - 32.5 volts DC driving the regulation circuit. The regulation circuit then puts out the + and - 22.5 volts DC as I noted. I get this 22.5 volts under full load or with the power supply removed and no load connected, so it clearly is regulating to the 22.5 volts. The regulator circuit has a 15 volts zener diode that is actually measuring 14.5 volts and two transistors. The output voltage is divided across a 3.9 k and and 5.6 k resistor to feed back to the regulator. With the 15 volts zener (14.5 v actual) and the two transistor junctions, the circuit cuts off when the feedback voltage reaches about 13.2 volts. Interestingly enough, if you backup the drop across those resistors, you get that 22.5 volts out will give the 13.2 volts to the regulator, so it appears to be designed to regulate to 22.5 volts.
Mine is a MTR-10 II.
I get 22v using my analog meter measured on pin 1 on the takeup tach board.
The thing is built like a tank I'm suprised they didn't just weld the thing together and save on the cost of the screws.
I knew you were waiting and I didn't have the proper tools handy so I traced it from the topside. jer
Let me know if there is anything else I can help you with as I have the following decks and manuals. jer
TASCAM 38
TASCAM MSR-16
OTARI MTR-15
OTARI MTR-10 II
TASCAM 38
TASCAM MSR-16
OTARI MTR-15
OTARI MTR-10 II
Thanks so much for checking for me. Measuring under the deck is just as good as any. I am not sure what the difference is between the MTR-10 and the MTR-10 II. However, the fact that your schematics show 26 volts but measure 22 volts gives me confidence. I was pretty much convinced that must be the case based on my review of the circuit, but this relieves any doubts I had. I had a suggestion that Otari might have had some issues with heat dissipation and so lowered the voltage on later model MTR-10s without changing the labels on the rails either on the schematics or the front panel indicator light. I have run into several other things that suggest Otari might have made more changes than one would expect between the different series of these machines. Anyway, thanks again. At this point the only other analog tape recorders I have are Otari MX5050 series (II and III) and two Magnecord tube decks (1028 and 728). And, yes, I agree that the MTR-10s seem to be very well built.
Your very welcome!
I also have some teac 4 tracks and 2 tracks as well as a TASCAM 22 1/4" half track that recently found schematics for too.
Good luck. jer
Good luck. jer
Geraldfryjr, One more question if you don't mind. I started calibrating the audio electronics, and ran into an issue with azimuth. The manual says to put the playback of the outer two tracks on a dual trace oscilloscope, play back first 8 kHz and then 16 kHz tracks on alignment tape, and adjust the head screw until the two sine waves align. When I did this, the lower track would not stay still on the scope. It danced around a probably about a quarter wave of the sine wave. I tried to set it so that it danced equally around the center of the top channel, but this did not feel good. Have you set the azimuth on your MTR, and did you see something like this? Thanks.
I haven't done an alignment on the otari yet but I have done them on my teac's years ago.
I what you are seeing is the actual flutter that the machine creates.
Here is why,
Your scopes trigger is set to one channel and what ever that channel is, the wave form on that channel will remain to appear stable and locked.
If you switch the trigger source on the scope to the other channel, then the results would be switched and the bottom track would remain stable and the top track would appear jittery.
If you set the trigger to both channels the both would remain rock soild stable and any azimuth adjustment would go undetected.
Only one channel can be set to trigger as this becomes the refference.
Are you working with the two track version or four track version? jer
Here is why,
You are correct that whatever channel is the trigger appears stable because it is the trigger. The other channel bounces around a bit. I had not thought that it is reflecting the actual flutter. I guess that means it is inherent. It is also worse with higher frequencies, based on the space on the tape. I had always just set azimuth by maximizing the output on both channels, which is not as precise. Have you learned any tricks to make it easier? I have a four track MTR-10 but I have converted it to a 1/4 two track by replacing the guides and head assembly.
The reason why I asked is that with a multitrack head if you start with the outside tracks there is posiblity to have the adjustment appear aligned but actualy be a whole complete cycle off.
So,If you decide to go back to four track start with the inner most adjacent tracks (2 and 3) then recheck using the outer most tracks (1 and 4).
Then recheck again using a higher frequency as this will allow you to make the adjustment much finer.
Hence the higher the frequency, the straighter the azimuth adjustment.
I know what you were thinking as I did when I frist saw it .
That flutter looks pretty scary and it is amazing that you can't hear it ,so, imagine how it would look if you could hear it.
If there is anything else and I don't catch the post right away just PM me and I will responde quickly . jer
Good advice. Thanks. The idea of starting with the inner tracks in a multitrack setup, and of starting with a lower frequency and working up in all situations, makes a lot of sense.
Now, I am having problems with my MTR-10.
At first the capstan would start then shut down.
Then after trying a few times, nothing.
Finaly, I got it to stay running buy hitting the edit/unload button.
Before this nothing would work, including any sequence.
I finaly got it to play for a few seconds and then it stopped.
It has been sitting for a while and I had only used it briefly when I first brought it home from Florida last year in august/september of last year.
Is there any thing I should look out for?
I will try reseating the cards next, as far as I know they have never been touched since the day it was received in 2002.
Also when It stopped playing,it was right when I had lightly stepped on the remote cable by accident.
And after that I was back to square one and not playing.
So I then disconnect the remote cable and switching the remote switch did not render control of the deck from the top of the deck controls.
Also when I first powered it up the LED displays on the topdeck were not lighting up but now they do.
There is no proper strain relief on the remote cable on one end and that end that is on the remote control.
Can these ends be swapped to eleviate this problem?
On my machine I first had an issue with the remote switch on the back of the machine and had a problem of which set of controls was in control.
Is this normal?
It may be the cable and/or the one connector on the one end.
I figured I would ask if you or anyone had experienced these problems before.
Before I have to setup shop to fix them, as my MTR-15 does not record at all but plays back fine and needs to be repaired anyway.
The MTR-10 did record and playback perfectly when I got it home.
Although it did exhibit a bit of a too much torque problem on the takeup reel (I think)in one of the spooling modes and some times seems in operable and the CPU applyies the brakes on the other side.
I have had similar problems on the MSR-16 when in edit mode.
As this setting is a very touchy setting on all high quality decks.
I know from past experiences that if you let these devices sit too long without being used problems can occur.
I had the capstan problem happen with my MSR-16 after it had sat without being powered up for a couple of years ( 2 or 3) without ever being relubricated since the day it was bought new in 1994.
But after a while it loosened up and stayed running, as this is a built in safety feature to keep the motor or amplifier driving the motor from burning out.
Which at first I thought was the problem with this MTR-10.
But it seems that it could be deeper,But at least it is not compleatly dead.
Any help or suggestions would be greatly appericiated as I do have the service manual but not the time right now to tear it down. jer
Is this normal?
Anyway I get in to edit mode and start getting deep into detail and the 30 minute mark comes up and I loose every thing I had typed.
So ,if any one knows these types of problems any suggestions would be great. jer
- Analogue Source
- Otari MTR-10 Voltages
