hello.
my apologies in advance - this is my first oscilloscope.
I recently bought a Beckman Industrial Circuitmate 9020 without a probe (manual here)
if I'm not mistaken, I should be looking for a 10x passive probe w/ high bandwidth and a bnc connector, but im not sure if im overlooking anything.
am I?
thanks in advance.
am I?
thanks in advance.
hello.
am I?
thanks in advance.
Well, you need to ask yourself: what's the bandwidth of the signals I'll be looking at; what's the impedance levels of the circuit points I'll be probing, and what are the signal voltage levels?
A 1:10 would be good if you are looking to signals above 10V or so, otherwise not necessary (although a switchable 1:10 - 1:1 is usefull).
For bandwidth, it probably not worthwhile to look for a probe with a (much) higher bandwidth than your scope.
Finally, check that the probe is compatible with the scope input impedance. Most scopes have a 1megohm input impedance, and most probes (except special hi-freq ones) are compatible with that. Note that a 1:10 probe will bring the loading on the circuit from 1 megohm to 10 megohm, but thats not really necessary these days.
jd
