Hi everyone I'm new on the Forum And Comment My Problem:
I Still Have This Orion amp And I Conect to the amp at 8 Ohms My Kickers L7 4 Ohms DVC first day work fine but second day it blown, so i open it and find 4 irfz44n transistor burned, so i replace the four transistor and check the 100 ohms gate reistor and they are fine,so i power un the amplifier with a 10 amp fuse and 12v bulve for proteccion, but when the amp turn on,it put itself on protecion mode and the bulb blink and the green led of power blink to, i check the transistor diodes and are good anybody some ideas can help me?
I see that nobody is interested my post, but just as I put an update.
apparently damaged 3 output transistors which caused the burning of the 4 irfn44n
then
4 IRFZ44N replaced, 3 output transistors by replacing
checking resistance of door and look good.
I hope some recommendations or tips if it does not matter anyway
then
Hey Please, a moderator move this post to the righ place i' think im in the wrong section
maybe car audio section thanks and im sorry!!
this is part of the work
no sir, I ordered the parts on Digikey and yes i buy the exact replacement you think i need replace all the 8 of channel or the damaged lot only?
This is a 4 channel amp. It appears that you removed all 4 FETs from the defective channel.
I don't understand what you wrote.
Are the new FETs installed (yes or no)?
Before applying power (after replacing the FETs), set the bias pot for that channel fully counter-clockwise. Also clamp all transistors and insert a 15 amp fuse in the B+ line to provide additional protection.
I put all the new fet's also clamp,I power up the amp but it get hot only on the side i replace the fet's. Some ideas
ok i set it on the way you show me and the dc amps are at 1.88 amp and the transistors not get hot, only a little bit passed 15 min or more.
a question, is correct if Iconnect the amp on series with the b+ of the amp?
- General Interest
- Car Audio
- Orion Xtr5004 Failure
