Orion HCCA5000.1D
This amp came with shorted outputs so I replaced them and the IR2110S. With the outputs in the amp I have rail to rail oscillation but it goes from 140volts to 40 volts and starts to draw 9 amps. With the outputs out I don’t get any low side drive unless I short pins 6&7 on the TL072.
Yes I removed the jumper on the feedback op amp. I turned the amp over and seen a 1 ohm resistor across R180 and removed it due to not looking like a factory modification and the amp produced normal rail to rail oscillation. I Checked that 1 ohm resistor out of circuit and it’s reading 1 million ohms. I’m not sure why this was added R180 is an 270K ohm resistor.
With no rail to rail oscillation there is 3 volts offset. With rail to rail oscillation there is 0 volts. The amp isn’t producing audio, it starts oscillating at 140 volts then goes to 40 volts like before while drawing 9 amps of current.
