i have a orion xtr 2000.2 .2 mosfets keep getting hot and blowing out ..the all getting the same voltage of 4 volts on the gate and the resistors good also 47 ohms it carries ...all other mosfets cold and the amp playing if i remove the 2 mosfets that over heating..
Do you have a scope?
What components had failed when you received the amp?
Are the two missing FETs the ones that are overheating?
Do you see an increased current draw when the overheating FETs are in the circuit?
If so, how much of an increase?
I don't have a scope ..the current draw when the fets are in the amp is more than 5 amps and more .
Current draw without heating FETs?
Current draw with heating FETs?
