Hi!
Can´t say - yet. Just ordered a pair of double C core SE outputs for my Tubelab SE. He doesn´t speak English, but that can be circumvented reasonably well using Google translator. Hopefully they will be installed in about 4 weeks.
Some time ago, I bought a custom-wound power transformer from Ogonowski. Very nice workmanship, fair price and made perfectly to spec.
Rundmaus
Rundmaus
Can you report back the impressions of Ogonowski OPT (which model did you buy?)Hi!
older thread, but i can report on my OTs from O.
I use his OTs, based on EI84 core (LO-SE25, custom gap) for almost 2 years.
i won't try to describe the sound since it makes no sense. there are nicely done, no-mystery classic construction transformers, German M6 steel (at least EI type), paper insulation, varnished or not (you can decide), most parameters can be changed without additional cost. reasonable priced and the waiting time is among the shortest world-wide.
in my current build i want to try another maker, but just for the feeling that i do something differently, not repeating, limiting myself. sound-wise it would be satisfactory for sure.
So far I have a pair of SE25-3 double C core outputs in my Tubelab SE. Their performance is very good, both frequency and phase-wise. They look good too!
I recently acquired a set for an Audio Note Kit4 clone (2x PP40-2 and 1x TS180-5), but this is still in the assembly stage. Hopefully testing will start soon.
The lead time in my case was about 4 weeks for each order.
I have the 6C33 OPT and Choke and waiting a custom power 400W EI, same core used in the power trafo GM70 Lampizator.
Photos:
Let's See Your Transformers!
No complaint so far, Mr.Ogonowski do what I ask at no extra cost.
Photos:
Have you had a chance to listen to the 6C33 OPTs? I am considering them for my 6C33 monoblock project.
Not yet, just for 2016 or late 2015, but they look great.Have you had a chance to listen to the 6C33 OPTs? I am considering them for my 6C33 monoblock project.
- Tubes / Valves
- OPTx from Ogonowski
