Optoma dlp EP719 not working need help
My projector has about 1600 hr on the bulb and it will not turn on. There is a lamp led on the top. When the bulb is out the led should stay on. When I turn on the projector the lamp led will turn on for about 1 sec. The projector sounds like it is trying to energize about 3 time and it will turn off. there is a board between the lamp and the psu. I belive it is a inverter. I tested the voltage and there is dc voltage going from the psu to the inverter. On the output side of the invert where it go to the lamp there is no power ac or dc. Does anyone know what the problem is?
