Options for Big EI Transformer and Caps
Joined 2008
I have a couple older pro audio amps I will likely never use and am researching what I could do with their overbuilt power supplies.
The big EI transformers are 60-0-60VAC. The filter caps are 15mF/100V. Each amp has one transformer, 2 big caps, and +/-80VDC rails.
Please forgive my ignorance, but I have some general questions about building something with these:
  • Can a hefty, adjustable bench supply be made from these?
  • Can higher voltage transformers be brought down to lower AC voltage to allow for flexibility in application?
  • Can an existing +/- 80VDC power supply be converted down without compromising the abundance of VA available?
  • Is it feasible to build a modular power supply such that:
    • Main power Tx is high VA, higher voltage secondary
    • AC is brought down to a specified value
    • Rectifier accepts final AC figure and feeds DC to filter capacitor bank?
From my meager research so far, I'm assuming the wise answer is "Forget the big transformers. Sell them and get something you can use." However, I wanted to ask the power supply gurus, first.
Reactions: NanoFarad
The raw DC voltages can be brought out of the amp (from a point after the rail fuses) to connectors
like banana sockets, terminal strips, etc. This way you can leave the amplifiers otherwise intact.
You can reduce the DC voltages by using a Variac (with a suitable rating) on the line cord. The VA will decrease
directly with the voltage, because the max current cannot increase. You will need a Variac anyway.
The rectifiers won't care if the voltage is decreased.
Reactions: von Ah
If you have the need for a +/-70V lab supply (to test amplifiers for example), you can certainly use the power (expensive) part of the amps. Otherwise, recycle them in the best way you can.
I have converted a similar supply (not audio though) into a test supply for amplifiers, but I felt a need for such a thing. If you do feel the need for such a big supply, dispose of them in the most advantageous way for you
Reactions: von Ah
