Opamps (i.e. OPA627/2132's etc.)/Transistors/Schottkys/Dioges/Capacitors for SALE
The following are all new:
10 OPA2132P(A) 8 PIN DIP ($20 for 10)
3 OPA627AP 8 PIN DIP ($25 for 3)
5 THS4031 8 PIN SOIC ($5 for 5)
5 THS4032 8 PIN SOIC ($5 for 5)
2 AD8065 on Browndog DIP adapters ($10 for 2)
2 AD811 8 PIN Buffer DIP ($6 for 2)
2 LT1010CT 5-PIN Buffer ($8 for 2)
Take all of the above OPAMPS for $60
15 100uF 50V Panasonic FC Loe ESR Capacitors ($5 for 15)
10 LM337BT 1.5A NEG. Adj. Regulator ($5 for 10)
10 LM317BT 1.5A POS. Adj. Regulator ($5 for 10)
6 LM350T 3.0A Pos. Adj Regulator ($6 for 6)
20 LM337D2T 1.5A Adj Regulator ($10 for 20)
Take all the regulators for $20
5 Fairchild FQA12P20 12AMP 200V P Mosfet Device ($5 for 5)
5 Fairchild FQA19N20C 19AMP 200V N Mosfet Device ($5 for 5)
5 Fairchild FQP3P20 3AMP 200V P Mosfet Device ($2 for 5)
5 Fairchild FQP4N20 4AMP 200V P Mosfet Device ($2 for 5)
15 Fairchild KSC1845 TO92 ($3 for 15)
10 Fairchild KSA992 TO92 ($2 for 10)
Take all the Fairchild MOSFet/BJT's for $10
8 MBR3100 3A 100V Schottky power diode ($5 for 8)
20 MBR20200G 20A Schottky 200V power diode ($10 for 20)
10 MSR1560 15A 600V Ultrafast /soft recovery diode ($5 for 10)
10 1N5404 3A 400V Power Diodes ($4 for 10)
10 MUR460 4 A 600V Power Diodes ($5 for 10)
Take all the Schottkys/Power Diodes for $20
10 BC490C small signal transistor TO92 ($2 for 10)
10 BC550C small signal transistor TO92 ($2 for 10)
10 BC560C small signal transistor TO92 ($2 for 10)
5 MJL3281A 180W 15A 260V 180W NPN Transistor ($6 for 5)
5 MJL4302A 15A 350V 230W PNP Transistor ($7 for 5)
5 MJL4281A 15A 350V 230W NPN Transistor ($7 for 5)
Take all the On-semi Transistors for $20
The following items are used:
8 (Qty) Slightly used Sanken FP1016 Ouput Devices 180V 70W 8A Darlingtons ($2 for 8)
8 (Qty) Slightly used Sanken FN1016 Ouput Devices 180V 70W 8A Darlingtons ($2 for 8)
10 MSR1560 15A 600V high speed soft recovery power diodes ($3 for 10)
Take the whole LOT for $120 USD + shipping
Payment thru PayPal or MO (for US/World) and Interac/personal check/MO/Paypal (for Canada).
Thanks,
I 'll certainly take all your THS4031 and THS4032 SOIC Op-AMPs ($10 for 10), and 5 MJL4302A 15A 350V 230W PNP Transistor ($7 for 5) and 5 MJL4281A 15A 350V 230W NPN Transistor ($7 for 5).
All these should fit easily into a padded envelope.
How much for airmail to Australia?
My direct email: janusz.pradzynski@dpi.wa.gov.au
PS I'll be at work for the next 2.5 hours. If I do not hear from you by then it will wait til tomorrow. I am a PayPal member so PayPal is OK.
cheers,
Since our time zones are 10-12 hours apart (its day here and night there etc). Give me your postal code in Aussieland. I will prefer to send it airmail (a little more expensive) since last time I did standard post to South Africa and the package took 3 months to get there!
I have a small bubble enevelope to ship the parts in.
Here the quote from Canada Post:
Small Packet International Air (See Canada Postal Guide)
Base Price $14.05
Coverage Included
Total $14.05
So PayPal for $38 USD is the price TOTAL ship to you.
Email me at dsmullins@sympatico.ca and we will work out the details.
Thanks,
Dan
opa2132
Hi Dan,
Airmail is essential. I do not want to wait months as I will be changing address in a couple of months.
OPA2132 are these P or PA version? Or some of each kind? If you gave me some rebate I could take these as well. With $14 for airmail I have to "optimize".
I'll be at work for the next 6 hours.
cheers,
Some items tentatively sold.
The following items are SOLD:
2 OPA2132PA
2 OPA2604's
2 OP275's
5 Pany 100uf 50 V FC caps
I have found 2 more additional OPA627AP for a total of 5
I will sell 5 for $36 US + shipping
Digikey sells them for $18 USD each!
Thanks,
Dan
UPDATED Parts for Sale
5 OPA627AP 8 PIN DIP ($35 for 3)
1 AD8065 on Browndog DIP adapters ($5 for 1)
Take all of the above OPAMPS for $45
10 100uF 50V Panasonic FC Loe ESR Capacitors ($4 for 10)
Take all the On-semi Transistors for $8
Take the whole LOT for $85 USD + shipping
Thanks,
