Opamp for low-voltage supplies
What opamp works well with low voltage supplies? I have an application where my supply voltages are limited to +/-5V and cannot be changed, so I was wondering if there was a decent opamp designed to work well at these levels?
Signal levels will be at a standard line level... (1VRMS or thereabouts).
There are loads of op-amps like that, thanks to the popularity of battery powered equipment. For instance, OPA365 seems to be perfect for audio (I have some myself, but haven't tested them yet).
EDIT: Not that one, as it has a maximum of 5.5V supply voltage. Go to Texas Instruments' site and look there - they do plenty of others.
Many so-called low-voltage opamp (with rail-to-rail inputs) have common-mode issues (ususally buried in the datasheet)... so run them inverting mode to stay out of trouble... but 10V total supply voltage is not likely to be a problem (<5V is).
- Klaus
I'm not sure if I want to battle a 3KV/µS opamp for stability.
I know that most opamps are rated for use down to +/-5V, but I thought there might be one or two that are both good for audio, and designed for low voltage rails... :nod:
