It is common in many bits of gear to see opamp power supply pins decoupled from the rails by 47 or 100 ohms resistors, and variable value of decoupling cap (electro).
Has anybody done measurements on the effects on distortion, envelope behaviour and dynamics of this technique versus differing values of resistor and cap ?.
Subjective test results are ok too.
Eric.
Eric.
Hi Eric,
I've never gone to the trouble myself to measure or to listen and comparing to different value resistors/coupling caps.
But I can tell you what I normally do.
First thing I do is to measure the voltage between the supply rails of the op-amp.
If it has a voltage much below +/- 15 volts (that happens very often), I try to find a way or raising the supply voltage to anywhere between around +/- 15 and +/-18 volts.
Sometimes the solution is simple, just lower the value of those resistors.
But sometimes I have to do something to the PSU, or even a new one.
The problem is, and that I tested several times, with a lower voltage than, let's say, +/- 12 volts, the op-amp behaves and sounds much worst.
I've seen cd-players with +/- 5.6 volts on the op-amp!
That's crap, because they share the same PSU for the digital and analogue section.
If the op-amp has couplig caps of 100 uf or larger, I don't touch them (but I bypass them with 100 nf ceramics or polyesters).
If it's lower (sometimes 2.2 uf, far from the op-amp!), I change it for something from 100 to 330 uf (and bypass near the op-amp).
I always, but always, put a ceramic 100nf cap between + and - pins of the op-amp (under the circuit).
Well, this techniques always work very well for me.
I agree with carlosfm with the solution. I just recommend another one:
In most of the equipment manufacturers use three terminal voltage regulators, for opamps. I often remove this regulators, and apply separeted zeners for each opamps.
I found that 15-18V zener bypassed with 100uF LOW ESR+100nF ceramic gives the best solution.
Of course series resistor with proper value is necessary for every opamp, and in every rails. Use the highest possible current - 1 or 1.3W zener strongly recommended!
Regards: Sajti
Regards: Sajti
Distorted Decoupling ?
Hi Carlos,
Thanks for your experience.
You suggest ceramic caps - these seem to be regarded as distortion sources, even when decoupling.
Regards, Eric.
Hi Carlos,
Regards, Eric.
Ceramics
Really?
I heard that about tantalums...
Well...
But the ceramics have good high-frequency characteristics.
Just try not to use them in the signal path.
This may lead to another huge thread, we can all learn from each other.
Really?
Well...
Thanks Eric,
I read that some time ago.
The main problem I have is that here in Portugal it's very difficult to buy good parts.
You can only find crap things for sale.
I would like to use more good caps, of different types, but it's very difficult to get them here.
If I whant something special, I have to buy abroad.
Oh well... sometimes I dream with Black Gates!
mrfeedback said:It is common in many bits of gear to see opamp power supply pins decoupled from the rails by 47 or 100 ohms resistors, and variable value of decoupling cap (electro).
I assume you mean the resistor is in series with the decoupling cap and not simply across the supply.
The resistor's just there to damp the resonance of the LC circuit formed by the decoupling cap and supply lead inductance.
I haven't but, but then I've never had any stability problems due to resonance of the decoupling cap and supply lead inductance so I've never used that technique.
Suffice to say that changing the value of the cap will change the resonant frequency of the LC combination and changing the value of the resistor will change the amount of damping. So unless you've already got a stability problem, I don't see how it would effect the parameters you mention above in any meaningful way.
se
Ceramic bypass cap
"You suggest ceramic caps - these seem to be regarded as distortion sources, even when decoupling.
Yup, but the function is to remove AC from the DC power supply by providing a path that looks like a short to AC but an open cicuit to DC. Noise and distortion are AC by definition. The important thing about the cermic caps is that they about the highest bandwidth of any type. If they distort, all they distort is the noise and distortion that is being shorted anyway. I suppose there might be some way they reintroduce some to the rails but as long as the net effect is lower noise, etc, you benefit.
Decoupling The Decoupling...
I mean a resistor connected between positive power rail and opamp positive supply pin, and a cap connected between opamp positive supply pin and ground - duplicated for negative supply.
The purpose is to isolate the opamp supply pins from fluctuations on distributed supply rails, especially in big systems like mixers.
The value of resistor and capacitor will effect the opamp's supplies during audio envelopes.
The question is, has anybody done serious investigation of the sonic effects of the values of supply series resistor and shunt capacitor.
Eric.
Eric.
Re: Decoupling The Decoupling...
Yes. The local supply will be modulated to a greater degree by the local opamp's current draw (i.e. the audio signal). The smaller the capacitor and/or the larger the resistor, the greater the local supply modulation. How much of that modulation that gets mixed in with the signal will depend on the opamp's power supply rejection.
You originally seemed interested primarily in measurements. Bascially measurements would simply show the modulated signal added to the output. No different than how supply ripple gets added to the output.
se
mrfeedback said:I mean a resistor connected between positive power rail and opamp positive supply pin, and a cap connected between opamp positive supply pin and ground - duplicated for negative supply.
se
I Will Repeat The Question.
Steve I well understand PSRR, and the fact that the supply pins will be modulated, and according to the level of PS modulation and the degree of opamp PSRR a valid audio output will result.
Eric.
The question is, has anybody done serious investigation of the SONIC effects of the values of supply series resistor and shunt capacitor.
Eric.
Re: I Will Repeat The Question.
Ok. So you weren't interested in measurements. Sorry, I must have been seeing things.
There it is again.
Time to go get my eyes checked.
se
mrfeedback said:Steve I well understand PSRR, and the fact that the supply pins will be modulated, and according to the level of PS modulation and the degree of opamp PSRR a valid audio output will result.
There it is again.
se
I Did Say 'SONICS' too....
Steve, it seems that you have not done measurements or else you would be presenting them I expect.
Ditto subjective sonics testing too or else you would be presenting your finding in this area too.
Has anybody any subjective data here ?.
Eric.
Eric.
Re: I Did Say 'SONICS' too....
Nope. I've never built any large multichannel mixers with gobs of opamps so I've never been compelled to resort to such a drastic measure as that.
What I stated above notwithstanding, I tend not to say much about my subjective experiences because I don't feel they have any particular value to anyone but myself. If they did, then they must not be very subjective in the first place.
se
mrfeedback said:Steve, it seems that you have not done measurements or else you would be presenting them I expect.
se
eric,
Even on cd-players, preamps, etc. sometimes I see resistors on the power supply lines before op-amps.
They are there to try to isolate the component from other components sharing the same PSU, and to reduce the current entering the op-amp.
I change their value only if the supply voltage is low on the op-amp pins (it happens very often, and you can get more 2 or 3 volts).
As for subjecctive results...
Well, everytime I get the voltage as I like, I get better results.
The sound is faster, cleaner and more dynamic.
I don't see a necessity to limit too much the current of a 7815 or similar. They won't hurt an op-amp.
Thanks that is the sort of reply that I was seeking.
Can you give values for particular opamps ?.
Thanks, Eric.
Eric,
In general, OPAs (2604, 2132, 627/337, 228/2228) like to be driven above +/- 10volts (this applies to most other op-amps too).
Below that you notice immediately they don't play as they should.
Maby some people don't bother with this, but it's really important.
An OPA2604 works until +/- 24v, but I never tried to go over +/- 18 volts.
I say that generally for any op-amp the optimum is between +/- 15v (the standard normally) and +/- 18v (the limit for the majority of them).
- Opamp Decoupling
