Hello,
I'd like to change the OPA2134 in my Prodigy Cube DAC with some other OPAMP. I'm just casual user and not sure which one can I use. User manual says:
Could you post some suitable choices for my Prodigy Cube, please? I've thought about OPA2228...
Texas Instrument's socket-type and replaceable OPAMP2134 allows user to enjoy user's own sound taste by replacing OPAMP with another.
...Regular OPAMP, DIP8 type, that can be driven by more than +-5V (for 627 series, 8620,8610 series, 5532 series etc.)
OPA2228 sounds like an alternative try, not much better or worse on paper.
LME49720 and LME49860 do have better characteristics on paper and a lot of people enjoy the transparency so you might also try those.
Try LM4562 - is avail in DIP capsule (LME49720 is the same product with newer name).
Ok, I'll give it a try, it's cheap anyway. Another one which I'd like to try is OPA2107. According it's specs, it can work even with 4,5V, so it's covered witch the USB 2.0 specification.
I just A/Bed OPA2134 and LME49720 in the input buffer & output stages of a Bozak ISO-X. (TL072 was the original.)
I wasn't expecting to hear any difference but couldn't believe the improvement in clarity with the LME49720 chip. The OPA2134, in this application, was not nearly as striking an improvement.
rs
rs
rs
When I hear 'striking' improvements I tend to get out the scope just to verify there isn't something 'funny' going on.
G²
Everything seems OK electronically. In this case, I think the opamp choice was made to give a "forgiving sound" since the unit is intended to be a playable instrument.
Indeed, the original opamp in all its "warmth" (tee hee) was hiding a minor resonant peak in the high midrange that comes out in certain circumstances. So, TL072 might have been chosen as a cover-up in addition to being inexpensive.
rs
rs
- Design & Build
- Parts
- OPA2134 replacement
