Hey peeps...
I have 3 AD825's, 2 AD8610's and 1 AD797 that i got sent. I wanna do a op-amp pre with plenty of gain that i can feed into some valve fuzz/saturator effect circuits. On the output stage it'd be nice to have a varible DC(biased) transformer so u could adjust the sound...plenty of knobd all round really...
Just wondering what more exprienced, knowledgeble ppl know or can give direction on as i'm a diy newbie...
rspx
rspx
Input from ....
And where is the input coming from?
An amplifier is an adaptor between
an input, a source, and an output to another device.
For a good adaptor both things are to consider.
soz, this was meant to go in the valves forum...
the input would be outboard (synths, drums and so on...)
Cheers...
Cheers...
Hi-Fi op-amps for MI applications?
Most MI effects use more common op-amps such as the TL072, 4558 or 5532. those devices you mention are gonna be a bit edgy as sources to be over-driven. the most hi-end I would go is the lf412 and the op-275 for MI applications.
Robert Morin
Robert Morin
