Only if I win the lottery
I'd start with (4) of these!
image_preview
JBL Project Everest DD65000 and DD67000 Flagship Loudspeakers Preview
Audioholics Clint DeBoer's First Impression? Pretty Cool
Why not? For some outlandish transducers, these must be it, at only $150,000 😱 for (4) of them. To start... Then you need the amps. Also each unit merely weighs about 400 pounds. That will make a floor pretty steady don't you think?
Everything is relative.
~ Albert Einstein
thinking outside the box often proves worthwhile.
and when we can't get out of the box,
doubling the number of boxes might help .
100%
and the fact that when discontinued,
their value will most likely go up.
this poster is a huge fan of 'thinking big' .
such as this system from a blog in japan.
and,
the ceiling is high enough that there is room
for the owner to stack four more 4350's -
attachment.php
C'mon It's the lottery, do these ....
~ Albert Einstein
Wow! These are all outlandishly sexyspeakers, and systems, and essential accessories!
Maybe I shouldn't count on the lottery? Alas I need to realistically upgrade my test equipment (measurements) bench with digital oscilloscopes, spectrum analyzers, plus soldering / desoldering vacuum station, universal programmer, etc, and figure it will cost at least $10K (maybe a bit more). First things first for DIY. Yay!
Why not?
Nearly all men can stand adversity, but if you want to test a man's character, give him power.
~ Abraham Lincoln
Generosity is giving more than you can, and pride is taking less than you need.
~ Kahlil Gibran
You give but a little when you give of your possessions. It is when you give of your heart that you truly give.
~ Kahlil Gibran
One has a million times better chance of injury in a car accident......so I don't play anymore. Guess I'll have to earn it the old fashioned way..........But this would look nice in the house.
_____________________________________________________Rick.......
