If I change the default view 20 items to any other setting it immediately reverts back to 20 items.
It seems to work ok for me.
Hi Nigel. That is quite strange. Please try clearing your cookies. It's possible it's a HTTP/HTTPS cookie related thing, or something to do with our changed domain / CDN pattern. Once you've cleared your cookies (for *diyaudio.com and *dastatic.com) let me know if the problem persists. If after that it's "only you" having the problem (unlikely), then it could possibly be related to your ISP doing some over zealous caching. In that case, you could try tethering to a different ISP (say sharing wifi on your phone, from your mobile phone connection, if it's a different company) and seeing if you get a different experience.
I see 40 posts on my front page and 50 in the threads. Where are you setting the number of posts? I don't find a setting just for the front page.
http://www.diyaudio.com/index.php
Its acting differently today.
It had 40 posts on to start with.
I set it to 100 and it now wont change from 100.
In user CP Edit Details you can set the number of posts seen in a thread. Yeah - I've also only ever seen 40 on the front page.
Very strange. I can switch back and both for the number of posts in a thread, but front page always stays at 40.I set it to 100 and it now wont change from 100.
Yes.In user CP Edit Details you can set the number of posts seen in a thread.
Hmmm...I set it to 100 and it now wont change from 100.
Me too.I can switch back
Its probably the page being cached.
If I change the number of posts on the page the page briefly flashes as it redraws the page. So IE is probably seeing the same page being requested so takes it from the cache.
The good news is that if you're still having the same problem on all 3 browsers, and you're the only person having this problem, it's clear that something common to all 3 browsers is the problem:
The solution lies in changing some of these variables. I would first see if you can change the ISP / Internet connection by tethering to your phone as ISP caching is an obvious one. Then look for common browser extensions as they should be easy to identify (and you can probably restart your browser without any extensions, to test). Then it's down to the operating system or programs that interfere / "help" with internet data input / output, malware checkers and antivirus etc which can be turned off for a moment to see the effect.
- Computer
- Common installed extensions in all 3 browsers
- Software installed on that computer that purports to "help" you in some way / speed things up / antivirus / etc
- The internet connection
- The ISP
- Site
- Forum Problems & Feedback
- Only 20 titles displayed on front page.
