I have an Onkyo subwoofer Model# SKW-570. On the back of teh sub it has a line input "jack" (not sure if it is called a jack). I have looked everywhere to try to find this part and I can not find it. It is soildered into the board. If anyone can help with a schematic or part number or where to look for one I would greatly appreciate it! Thanks for your time.
Ed
Ed
Hi Ed,
In the manual it looks like a standard RCA socket, try
PCB Mounting phono sockets
Hope this helps, Josh.
JOSH>>>>> Thank you very much. I am by no means a expert on this stuff!! I try to fix things myself and know how to solder and desolder and thats about it. I do not know all the correct names as you can tell. Thanks again I really appreciate the help and time!!
Ed
Ed
Is there a supplier in the U.S. that carries this part. Also on my part it has a place for a screw to screw in on top of the socket does anyone know where I may find this type of PCB Phono Socket? Thanks again for your time and help!
ED
ED
Hi Ed,
Difficult to search the US from here (I just discovered!) and the screw mounts seem to have the mount just off to one side like these...
Switchcraft : PJRA SERIES RCA 1X1
The bottom few have the mounting lugs attached,
Again, hope this helps though, Josh.
