Since I have some very strange noise problems, I'm looking for a service manual or schematic for my onkyo integra dx-7500 cdplayer.
Occasionally, I can hear some kind of white noise coming out of speakers when I try to play a CD and this sounds really horrible. It doesn't seem to happen on a regular basis, but every now and then it's there. I can tell you, it is pretty irritating when you cannot listen to your cd's......😡
Hopefully, someone might have an idea what could be the cause of this problem, or can help me with a service manual.
Greetings,
Martin
Greetings,
Martin
Hi culcanmar
Open the player and look at the soldering side of the boards.
Look for bad joints particularly at the voltage regulators.
Look where the board became slightly brown or darker (heat)
Resolder every bad joint carefully.
But first of all, discharge the main cap(s).
/Hugo - Would be happy if the problem was solved 🙂
