Hello again!
I'm having trouble with an onkyo cr-l5 that doesn't come out of standby. There was a leaking supercap that I already replaced without any change. If anyone has it or fixed one of these with the same problem that would be very helpful. I tried forcing the power relay to close by shorting one pin to ground (with a dim bulb tester), the amp comes on (dim bulb flashes and turns almost off) but the standby light stays on and the display doesn't come on, no commands work and there's no sound. I'm guessing like the Onkyo cr-305 thread there is something wrong with the standby power supply but without schematic it's really hard to troubleshoot. I do have +5.6V and +10.6V coming from the board with the little standby power supply.
