One Half 12AU7
The 7 pin mini 6C4 contains a single triode that's electrically equivalent to the pair in a 12AU7. So, that's an obvious possibility. Another option is to use 2X 12AU7s, with only a single section energized. Wire Channel "A" to use system 1 and Channel "B" to use system 2.
