I need to switch between Optical or Coaxial on my dac and I would like the button to be on the front, so I thought I'd use an SPDT relay so I won't need to run signal wires down the case (twice).
I have an Omron G5SB-14 relay on my parts box and I know it would do the work. My question is whether you consider that a good solution and that this specific relay won't degrade the signal by any significant figure.
Thanks.
Thanks.
The relay will de-grade the signal. There are better relays, cant get to my stuff at the moment for part numbers, but on reflection i have seen similar signals switched via a relay, but ultimate fidelity was not the main concern but having an unbreakable communication network.
Could you provide a quick schematic of what you want, so there is no ambiguity.
I have a Valab NOS DAC that I modded, it comes with an SPDT switch on the back, that selects between Coax and Optical. The common is connected to the DIR9001 receiver, A to Coax inner ring, and B to optical TTL if I'm right (after the jack that translates light to electricity).
I want to bring that switch to the front. So I used a relay, and connected the front switch to it's coil.
I have two other relays that I can use:
1. Omron G6H-2 5V
2. Takamisawa SY-5-K 5V (gold contacts)
Also I can think of two other ways to accomplish this:
1. Using two discrete FET's to form an SPDT switch (N & P).
2. Using a 8ch analog mux, like 74HC4052.
Here are the schematics: https://www.dropbox.com/s/ylsvh1ytq6smg73/k-1.pdf
The switch I'm talking about is "SW1".
Thank's!
1. Omron G6H-2 5V
Thank's!
Any active component (FET, buffer) will add noise. In other words, it will introduce jitter. Therefore I think using a relay is a good choice, provided the relay is designed for RF. Not sure about the types you mention, but a reed relay should perform well.
Cheers
Sebastian
Cheers
Sebastian
You have a mechanical switch there anyway, so a decent relay will suffice, as stated RF, small signal.
I think you misunderstood me marce, I want to replace that mechincal switch (SW1) with something that I can control with 5v logic remotely (from the front of the case) 🙂
Thanks sebastian, unless someone thinks differently, I'll go with the relay (probably use the Takamisawa).
No, you will be switching the signal with mechanical contacts either way, be switch contacts or relay contacts.
The fact that I have a mechanical switch there already, doesn't matter, because it will be replaced (either with a mechanical relay, or a piece of silicone), so what I try to say, is:
Should not be a factor.
And if you meant by saying that, that there won't be any sq degradation because originally there was a mechanical switch anyway - I say that the original design is not necessarily "good", and can be improved if it needs to be 🙂
(That's why I came here)
- Design & Build
- Parts
- Omron relay G5SB-14 & S/PDIF / Optical
