Omnes Audio MW6(B) opinions / experience?
Omnes Audio MW 6 opinions / experience ?
Hi all,
Someone offers 2 pairs of these 6" midwoofers for 15 Euro a piece while i'm looking for midwoofers between Vifa XT300 and double 11" subwoofers (closed box).
This will be powered by 3 stereo amps on an electronic (analog) cross over.
They have to be able to reproduce appr. 100 Hz to 2 kHz.
Any thoughts, experiences and opinions on these Omnes Audio MW 6 midwoofs?
I can't find much about them.
Actually, i can't find anything about them...
Okay, so it's MW 6 B afteral..
The B stands for black.
It's better known from the Omnes Audio Spirit MW 6.
This is a d'Appo 2 way speaker.
So it's a decent midwoofer with a decent engine, but nothing too special.
I llike the S shaped suspension ring though.
I have MW6 paired with Tang Band 28-847SE. This woofer is definitely capable of handling better tweeter, but I have nothing at stock with such size. Size matters for my project, that's why Im using it.
XT300 would be good pair I guess, I have just tried to sit Vifa XT25 next to MW6 and it sounds more pleasant.
TB 28-847SE has some dull/harsh coloration on lower freq. range (cca 4-9kHz), although it appears quite well in distortion figures.
XT by Vifa has more detailed sound to compare.
MW6 has light cone, hence good impulse response. I have it in cca 12L/44Hz box and it runs from 40Hz@-10dB on stand 30cm from floor, meter away from walls. It is delivering very well in kick bass range, sounds clear and distinctive.
Where have you found MW just for 15/pcs? I would by some more.
