I have got my hands on an old Tektronix plug-in unit (preamplifier) for a scope (tube based)...
The unit is in very good condition and with protective cabinet. Inside is nice components and workmanship, and some tubes. 2 are 12AT6 and 3 are other in smaller housing...
Anybody now something about this unit?
I was thinking of using it as base for a tube preamp, because I like the old design and also the housing....
http://www.slack.com/images/TE/TekTypeK.jpg
If you're lucky, the components are mounted on those excellent ceramic terminal strips. If you re-use those (highly recommended!), make sure to use silver-bearing solder, otherwise the strips will fail.
Stripped and gutted, that could indeed make an excellent preamp case.
Yes they are Telefunken, and I don't think the have been in use much...
Regarding the silver solder, why is that and where to get right solder?
Nearly every solder manufacturer makes a silver-bearing solder. I use a 2% silver solder (62/36/2) bought from Radio Shack- with the Euro-Nannies banning lead-containing solder, you may have to use your imagination in sourcing some there. The metallization on the ceramic strips is silver; conventional solder will dissolve it and cause the metallization to lift off.
Useful bit of information there. Thanks!
Tektronix used to supply a small roll of the correct solder in every unit. It was on a small plastic bobbin inside the storage bin. Those were the days!
Craig
Craig
IIRC, WBT solder is 96% Sn and 4% Ag. It's costly, but it meets both HIFI and RoHS requirements.
Those TFK ECC81s will do very nicely in an "El Cheapo". Current production "reissue" TungSol 6V6s as "finals", along with good O/P "iron" would finish things off well.
- Tubes / Valves
- Old Tektronix unit, usefull?
