old scanspeak 15" woofer specs. Help!!!
I have an old scanspeak 15" woofer number 42w something from before the old factory burned down that I lost the specs on, anyone have the specs? It has a cast mag frame, doped cone, and cloth surround. I'd love to use it if I can.
My old Scan Speak short form data sheet (10.82) lists two 42W models;
42W8591
Fmax recommended: 800Hz
Sens: 96dB
Rated power @ x-over freq 800Hz (12dB/oct): 150W
Pulse Power (10mS): 900W
VC dia: 63mm
Winding Width of VC: 16mm
Height of air gap: 9mm
VC Res: 5.8 ohms
Gap flux density: 1.15T
Bl factor: 14
Res freq: 22Hz
Eff Cone dia: 330mm
Dyn Mass: 86 x 10exp-3 kg
Compliance Cms: 0.6 x 10exp-3 m/N
Mech Res Rms: 7 ohms
Equiv Vol Vas: 600 L
Mech Q Qms: 1.7
Elect Q Qes: 0.31
Total Q Qt: 0.26
42W8593
Sens: 96dB
Rated power @ x-over freq 400Hz (12dB/oct): 200W
VC dia: 63mm
VC Res: 5.8 ohms
Bl factor: 14
Res freq: 15Hz
Eff Cone dia: 330mm
Dyn Mass: 95 x 10exp-3 kg
Compliance Cms: 1.2 x 10exp-3 m/N
Mech Res Rms: 6.3 ohms
Equiv Vol Vas: 1200 L
Mech Q Qms: 1.4
Elect Q Qes: 0.27
Total Q Qt: 0.23
Hope this helps.
