Okki Nokki Record Cleaning Machines at MCRU
I am pleased to announce I am selling the Okki Nokki RCM's now. Excellent for the money (under £400 ) and a lot less noisy than most competitors offerings.
Available in white or black and in stock now. See my website for details.
Unlike other machines of this type;
Built-in safety features prevent fluid being sucked into the vaccum motor and the turntable motor overheating.
Made in Germany with the highest build values.
Cool running turntable motor allows for hours of use, no need for noisy fans.
Forward and reverse motor for 'scrubbing' action.
Quiet vacuum motor.
Auto shut-off should the user forget to drain down reservoir.
Vacuum tubes for 10" and 7" records available.
Comes complete with concentrate and brush.
New, modern, lightweight design, available in black or white finish.
Virtually waterproof plastic / aluminium body gives increased stability.
Added soundproofing - the quietest of all comparable machines in its class.
Thanks for looking.
