nview spectra viewframe series cable
if your spectraplus is the same as the spectra C than this is the situation:
the connector that says Optional / Monitor is the one you use for a regular monitor .
there should be 2 other connectors
one says Analog (that is where you enter the special cable (that i make, and have made for some of this forum) and this cable goes to the vga theater (tv-3000)
the digital inlet = I HAVE NO CLUE !!!!
be sure to check the fans ( 3) they could be malfunctionning or out of order without knowing about it.
their size is 40 mm. i have changed one of them and have also added felt washers between the body panel and the fans, the noise reduction was remarkable.
I am adding 3 leds (to control each of them) to the panel. SECURITY IS MY LIFE.
cable spectra c
the cable that connects your monitor out on your pc to the analogue input of the spectra c costs $15 including shipping.
nicely made!
contact me per email and i can give you details.
hamdude bought one from me and he seems to be satisfied and sone other guys on this forum but they do not visit the forum anymore. their system works...!
