Noticeable difference in low freqs between two channels on a Drawmer DL221 compressor
I've recently bought an older Drawmer DL221 compressor. It's a nice box with a simple circuit design from the 80ies. One of the channels is quite lacking in bass, however.
Here are some pictures of the innards: imgur.com/a/G08cN. I took pictures of the ICs, as they might be contenders for replacements. There are five TL072's, and one NE5532 (equivalents).
Is there a usual cause for this problem? Capacitors going bad? ICs?
Thanks.
Low bass may indicate a bad coupling cap (or cap in a feedback network). Unfortunately recapping this one may be a bit of a pain, as all of the electrolytics are axial, and those have become a bit uncommon. So you'll probably have to look for caps that are used specifically for those functions.
A electroylitic cap would be favourite. Why not rig a couple of caps up with leads and croc clips and just bridge the caps in turn to see if you can pick it up that way. Just remember to turn the volume down before each test clipping.
I just did a quick check of axial caps and they seem to be available from major suppliers.
You're right, they seem to be available actually.
There are just not as many different variations of them.
Here is a list of 22µF 25V, caps from RS: Aluminium Capacitors - 22µF.
There seem to be one suitable axial. All the others are radial, but are some of them better than the others, for this application?
