Non Designer question: PS for KT150
Are you going to run it at the plate voltages applied for the 6550 tubes ?
The KT150 uses more plate current at its normal plate voltage (running ) than a 6550 or will you be under-running it ?
Thats not a problem according to those installed just a lower output but if you need to use its full potential can your mains transformer take the extra current needed without dropping the plate voltage ?
The AR-VS155 isn't your standard designed tube amplifier .
I can design you a board that will turn 8VAC into 6.3VDC using a pair of LD1085/LT1083 LDO regulator if you want. I got a use for this kind of board myself.
You will then need to source a toroidal transformer that will deliver around 8VAC 6A for two tubes. Getting 6.3 from a 6V toroid is damm near impossible considering the rectification losses.
PM for details.
