I built a TU-8200 last year along with the Matching Pre-amp.
I normally only adjust the volume using the pre-amp, but
upon turning the volume pot on the TU-8200 it is now noisy.
Where can I get a Better replacement pot that will last longer?
Thank you
Thank you
noisy pot
Can one not turn the pot to max setting, thereby by-passing it. I'm now looking at elkit 300B as my se otl got water logged in an accident and is un-repairable. I use a passive pre by Django. On a review of elekit, a passive was 'cleaner than the original pot.
you can replace with TKD 2CP-601 50KA
