Noise cancelling headphones may cause hearing problems
Five audiology clinics in the UK recently noted an increase in young adults with normal hearing who nonetheless struggle to process sounds in noisy environments.
Some experts speculate that constantly tuning out background noise with Active Noise Cancellation (ANC) might be a contributing factor, because the brain isn’t getting practice filtering out unwanted sounds.
However, this is only an emerging theory and it's important to emphasise that it's about the brain’s adaptation to sound, not about ANC physically harming the ears.
If you’re concerned, follow this advice: use your headphones in moderation and give your ears (and brain) some off-time in normal sound environments. The bottom line from hearing experts is that the ANC feature itself isn’t causing hearing loss or damage to your ears.
I read it here: https://www.soundly.com/blog/noise-...eficial to your hearing when used responsibly.
Reactions: Maserito
