Hi everyone,
having run the BEM for a modell, i don't seem to get a response curve in Vacs + i have an error message saying: "All sources muted (provide LE-network or enable Fixed Driving)"
Can anyone help out please?
Thanks in advance!
Thanks in advance!
Found the solution in another post on this forum. Thread can be found here.
by @HEXAAA
by @HEXAAA
And in AKABAK if you select the global tab at the top then go into fixed driving, enable it and set the weight to 'divide by jw', it should work, it only started working when I selected that, probably because I wanted to get an acoustic impedance output.
