I'm looking into changing the x10 NJM4580 op amps in a Behringer Mic Pre I have to Burr-Brown (now Texas Instruments) OPA228's.
Aside from the original IC's being glued on it all looks fairly do-able with my somewhat limited level of electronics knowledge.
Please forgive my ignorance, but I'm trying to find out which ti OPA2228 exactly, they come in a few different ways. P, U, UA etc'
Here is the original chips datasheet
http://semicon.njr.co.jp/njr/hp/fileDownloadMedia.do?_mediaId=152
and here is the datasheet for the 2228
http://focus.ti.com/docs/prod/folders/print/opa2228.html
If anyone has to time to let me know I''d be off and running.
When you refer to the NM4580 being glued on, do you mean its a surface mount chip soldered on? ie: is it about 7mm sized?
If you dont have good equipment and skills, you'll probably end up ripping/delaminating the circuit board traces off the board.
Also, do you know what purpose the njm4580's serve? The opa2228 although nice isnt unity gain stable. It needs a gain of at least 5. You would have better luck with the opa2227.
opa2228P = dip package
opa2228ua = smd [surface mount] size
opa2228u = same as the opa2228ua except with better tolerance.
