where to find them...
digikey has a limit of minimum 25 pieces... it is to much for me.... Also Onsemi will not send to Croatia....
is there any other source for those transistors...?
thanks in advance
thanks in advance
Zdravo !
I've made a quick look around the web, so the results of my search are not good for you :
Elfa -> NO
Dalbani -> NO
Farnell -> NO
Rapid -> NO
Sorry.
Max
Elfa -> NO
Dalbani -> NO
Farnell -> NO
Rapid -> NO
Sorry.
Max
Zdravo to You too.... 🙂 nice....
that is what i am talking about...hard to find.... only digikey and onsemi directly and neither of them is suitable for me... and i would like to use those two transistors better than anything - because i have allready finished project from Roender and no need to modify it.......the boards are very nice and clean ....
"because of Cob (400pF vs 600pF) and linearity".....
that is why i would like to find these two guys instead of anything else.... 🙂
Sparkle
You could use, without much worries, NJL3281/1302 if you can't find the "zero" version.
Mihai
Mihai
sparkle said:"because of Cob (400pF vs 600pF) and linearity".....
I'm not so sure that this is real or just an error in the data sheet. I believe that both parts use the same die inside and the only difference is the size of the package. One has the larger TO-264 package and the other has the smaller TO-247 package.
Mr. Hansen,
Both parts use the same TO-246, 5 lead case 340AA but the chip inside is very different ... only the thermal track diode is the same.
http://www.diyaudio.com/forums/attachment.php?s=&postid=1349161&stamp=1194858226
I've try both njl3281/1302 and njl0281/0302 in my amp. The "zero"version sound more smooth, more precise on highs, with no harshiness or sibilance. There is nothing wrong with the other version (3281/1302), but I prefer the "zero" version.
This is the schematic.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=111756
Regarding an old discussion about thermal stabilization method, it is not so difficult to implement a very simple method once you know the TC of the diodes and have all output stage transistors, including drivers and predrivers, on the same heatsink
Mihai
Mihai
Just as a point of reference, Bob Pease wrote an article "What's all this Vbe stuff" -- http://www.national.com/rap/Story/vbe.html
If you folks want, I'll carry the devices on my webstore at just enough markup to pay for shipping from DK, but I am not going to get stuck with hundreds of them.
i will need those transistors in January but more probably in February....
and i plan to make at least three amplifiers based on Roenders design (one for me and two for my friends)...i am very impressed with the design....but we lack in money (all three of us) so we will progress slowly....
i was looking for a suitable source for the devices in case some of us can't go together with the others related paying for stuff.....that is why i needed a source that is able to send me six by six devices or something - but not 25 of them that digikey can do....
anyway - i think it will be digikey afterall....so jackinnj i think that You do not have to bother only because of me....
i wonder how many guys are here interested in Roender design... if we can go together than maybe you can see how mana of the transistors are needed and make your order at ONsemi or somewhere .... for sure at the end i will need at least 18+18 (for three amps)...but i am not sure about the speed of buying...that is the real problem....
Sparkle,
I don't want to influence you in your decision, IMHO this is an amplifier which worth some financial efort - you will be rewarded with a warm and pleasant sound. DIY does not mean, in every cases, as little money as possible ... this was not one of my goal when i designed it, but contrary.
I'll recommend you to buy at least double the number needed of output devices and try to match them as close as possible.
The output stage is very critical and deserve much more attention, it will make the difference between a nice and an excellent sounding amplifier.
http://www.diyaudio.com/forums/showthread.php?postid=1351876#post1351876
Mihai
Mihai
roender said:Both parts use the same TO-246, 5 lead case 340AA but the chip inside is very different ... only the thermal track diode is the same.
Thank you for the correction. I don't understand why On Semi makes two parts with such similar specifications. It seems the only differences are the power (180 watts versus 200 watts) and the Cob (400 pF versus 600 pF). I will contact them to find out why they make two parts that are so similar. When I receive an answer I will post it here.
They are $4.09 each at Jameco -- I don't know the shipping cost from Jameco yet -- there was a deal with UPS for free ground shipping on certain items -- it will probably add about $0.16 per device if the shipping isn't free to NJ -- I ordered 25 of each and you can have them at my cost when they come in.
the Cob is important. it can mean the difference between the amp going into Common Mode Conduction at high frequencies.
it can be a problem if your source is tape and you use the cue button to skip through music.
Roender - thanks...hmmm...maybe to go on those 25 pieces in Digikey and buy them.... that way i will have more room to pair them...it is a better price than in Jameco ... arround 2.5USD....
o.k. it is done 🙂
i wil do it this way - at digikey....
o.k. it is done 🙂
Hi,roender said:Sparkle,
Mihai
for a single pair output stage, what parameters should be matched?
And how closely?
- NJL0281 and NJL0302
