Hey, Luc has a good selection of audio grade Nichicon caps. Great communication and even free delivery if you are around the area ....recommended !
Nichicon Caps
How much of an improvement will the Muse caps be vs. the VX(M) caps in a power supply such as the Linn Valhalla?
Nichicon Muse series
Hi!
VX series are not audio grade they are general propose but have rated voltage up to 450V,something that you don’t have in the’’Muse’’series maximum rated voltage is 100V mostly.Depends of your rails power of your PSU?But Muse series improved frequency response,coefficient, sound, acoustics and harmonics etc.There are designed for audio equipment.
Thanks!
Hi!
Thanks!
2200 uF 50V
Hii
at the first time i would like to order your fx 2200uF
50F but now it is out of order
can you order 2200 uF 50 V im glad if it is from FG family
maybe i buy 10 pcs
pls inform
Hii
maybe i buy 10 pcs
pls inform
Nichicon stop FX series production.
Hi Jeffry!
You can order directly from my website www.minisemi.com and yes the 2200uF-50V from FX series are out of stock and will be out of stock forever because Nichicon stop production and discontinued all the FX family and as been replaced by the FW family. We have stock for FW,they are gold color same size and quality of FX.Best regards!
Hi Jeffry!
- Vendor's Bazaar
- Nichicon Muse capacitors!
